by Tony Hart » Sun Nov 15, 2015 9:08 pm
When re-fitting a rear runner board to my S2 the back screw on one of the strips is just rotating with the nut. Is there a bodge/fix to secure the screw thread? Don't really want to buy a new set of four!
Tony
Tony Hart
by rossclark » Sun Nov 15, 2015 9:16 pm
Araldite?
by Toddy » Sun Nov 15, 2015 9:56 pm
+1 and I've used loctite as well
by Tony Hart » Mon Nov 16, 2015 12:02 am
Cheers. I will give it a go.
Tony Hart
by HxPaul » Mon Nov 16, 2015 10:15 am
One of mine did the same (series 2) so I removed it,drilled through the plastic and put a long flat head screw in its place.You have to look hard to see it.
by Wack » Mon Nov 16, 2015 7:13 pm
Best way I've found is to heat the head up on the bolt and press it into the runner so it melts itself in ,then immediately drench in water.
by coaster » Tue Nov 17, 2015 12:39 am
Wack wrote:Best way I've found is to heat the head up on the bolt and press it into the runner so it melts itself in ,then immediately drench in water.
Genius, I'm going to give that a go using a stainless bolt
by Tony Hart » Tue Nov 17, 2015 10:33 pm
Cheers Wack. Will give this a try first before I try the glue.
Tony
Tony Hart
