Series 2 Rear Running Board Leg Rubbers
Postby Granty » Mon Nov 09, 2015 11:14 pm
Guys -- Stupid question but what's the best way of fitting the rear rubbers that fit over the rear running board legs to rest against the inside of the panels? Am I being a trumpet but cant figure it out. hahaha - G
Granty
Re: Series 2 Rear Running Board Leg Rubbers
Postby Dennie » Tue Nov 10, 2015 2:13 am
Hi, the method I used was to put both rubbers into boiling water and use some lube on legs,I used Vaseline.Then take rubber on fixed leg then slide on with rounded face downwards and then push on and up and twist rubber around to have rounded face outwards .On other leg should be able to push down from top . Hope this may be of some help ,regards Dennie.
Dennie
Postby Toddy » Tue Nov 10, 2015 7:12 am
Dennie wrote:Hi, the method I used was to put both rubbers into boiling water and use some lube on legs,I used Vaseline.Then take rubber on fixed leg then slide on with rounded face downwards and then push on and up and twist rubber around to have rounded face outwards .On other leg should be able to push down from top . Hope this may be of some help ,regards Dennie.
Good Tip, I generally struggle with them using a hairdryer to warm up
Postby Granty » Tue Nov 10, 2015 8:41 am
Thanks Fella's -- on the task this week -- have a good day Boys - G
Granty
Postby Scooter Paul » Tue Nov 10, 2015 2:16 pm
Ha! Did this job only the other day. Exactly as Dennie said only I slid them up from the bottom onto an already assembled leg.
Paul
Scooter Paul
Postby burnside » Tue Nov 10, 2015 9:46 pm
5 mins in boiling water and they should slide on fairly easily, that's how I've done it in the past
burnside
Users browsing this forum: No registered users and 147 guests
