Crownwheel
Crownwheel
Postby Stevepshipley » Sun Nov 08, 2015 3:37 pm
Is it ok for there to be a bit of play on the crownwheel.?
Just stripped mine and found theres some play, is this normal
Stevepshipley
Re: Crownwheel
Postby petemaisey » Sun Nov 08, 2015 5:18 pm
Is it play on the bearings? That is normal. If it is play between two parts the that is not OK. You may be able to tighten up the rivets but really a new solid type would be better. Solid types must be fitted with a bronze bush because roller bearings will damage the inner face.
petemaisey
Re: Crownwheel
Postby Stevepshipley » Sun Nov 08, 2015 5:55 pm
Yes it's on the bearings.... - thanks
Stevepshipley
