Series 2 headsets
Series 2 headsets
Postby drivera » Fri Nov 06, 2015 7:26 pm
Starting the build of a series 2 I bought as a job lot of bits , how do you tell the difference between an Li headset and a TV ?
drivera
Re: Series 2 headsets
Postby lammydave » Sun Nov 08, 2015 7:51 am
if the switch housing is still attached, they will be different
Not sure if the part number for the headset itself is different for each model...
lammydave
Postby drivera » Sun Nov 08, 2015 9:45 am
No switch housings attached unfortunately , just wondered if anyone knew the part nos ?
drivera
Postby Dimitrios_231 » Sun Nov 08, 2015 11:36 am
I have seen these numbers
19261010 for TV
19061090 for Li
Dimitrios_231
Postby drivera » Sun Nov 08, 2015 12:06 pm
Cheers Dimitrious , that's what I were looking for :)
drivera
Postby tv175lambretta » Sun Nov 08, 2015 6:31 pm
or (presumably) headset base versions later in S2 production run
19061100 for LI
19261020 for TV
to go with matching brake lever support
19063001 for LI
19263001 for TV
Headset tops are the same Li/TV (I think)
tv175lambretta
Postby corrado » Wed Nov 11, 2015 3:24 am
Good picture showing the 2 different ones together in Sticky's 2nd edition on page 172.
corrado
Postby drivera » Wed Nov 11, 2015 10:30 am
Cheers Martin , I'll find a copy and take a look :)
drivera
Postby Dimitrios_231 » Tue Nov 17, 2015 10:17 pm
ΝOS TV175 S2
19261010
Dimitrios_231
