Crankcase Oil Leak
Crankcase Oil Leak
Postby drivera » Fri Jun 20, 2014 3:11 pm
Decided to strip my GP down yesterday and sort out the annoying drip from the crankcase gasket so armed with new stainless studs ,washers ,nylocs , gasket and clear silicone I set too only to realise the leak was coming from the brass level plug , not the fibre washer but the plug itself , come to the conclusion it must be either porous or have a split in it .
Thought I'd share with you in case anyone else has the same annoying drip .
drivera
Re: Crankcase Oil Leak
Postby Wack » Fri Jun 20, 2014 5:46 pm
They split if you do up too tight
Postby Lambr62 » Sat Jun 21, 2014 6:54 pm
My sump plug also seems to have a leak coming from hexagon socket as oil collects inside. Have bought replacements from a well known scooter parts dealer and both have sheared off whilst doing them up. Before anyone says you might be over tightening i was now where near the point where you are tightening against crankcase face. So if anyone can give me an idea where i can get a quality one and not from somewhere on the north east coast ! ;)
Lambr62
Postby Wack » Sat Jun 21, 2014 8:30 pm
Best I've seen are the MB stainless ones
