hand pump
hand pump
Postby avanti » Sun Oct 04, 2015 6:16 pm
Good afternoon fellow forum members , today on my series 1 (SERIES 3 ENGINE ) I had cause to change the rear wheel , this was difficult due to the panel handle bracket. it seemed the only way was to deflate the wheel !!! .
so can any one recommend a hand pump that is up to the job that I can stow in my leg shield tool box.
thanks in advance
Avanti KTF ..... :o
avanti
Re: hand pump
Postby HxPaul » Sun Oct 04, 2015 6:46 pm
Unfasten the centre nut and remove the hub and wheel as one,this way you can replace it without letting the air out.
Re: hand pump
Postby Warkton Tornado No.1 » Sun Oct 04, 2015 7:24 pm
HxPaul is correct, but hardly a practical proposition lugging a torque wrench & 27 mm AF hexagonal socket about to accomplish the wheel change in the middle of nowhere or rush hour traffic. Where would you stash the wrench? Down a trouser leg?
The clip that holds the brackets in place is best modified, or dispensed with, thus allowing the brackets to swing.
Re: hand pump
Postby drivera » Sun Oct 04, 2015 7:48 pm
Or change to Tubeless rims ?
drivera
Re: hand pump
Postby HxPaul » Sun Oct 04, 2015 8:13 pm
Warkton Tornado No.1 wrote:HxPaul is correct, but hardly a practical proposition lugging a torque wrench & 27 mm AF hexagonal socket about to accomplish the wheel change in the middle of nowhere or rush hour traffic. Where would you stash the wrench? Down a trouser leg?
I've never used a torque wrench on the hub nut.I have a series 2 and carry the correct size socket,a bar and extention and an allen key for the locking plate screw.They all fit in my toolbox.
Re: hand pump
Postby Warkton Tornado No.1 » Sun Oct 04, 2015 9:21 pm
TBH I was confusing the panel latch method with the Series III.
However, I still wouldn’t want to ‘guestimate’ upwards of 110lbs/ft for the sake of a puncture whilst holding the hub via the rear brake. I’m not entirely sure I’d be happy in carting the tools as you do in addition to the hub puller.
If that is the only alternative method to deflating the tyre though, I bow to your superior knowledge.
Re: hand pump
Postby Captain Pugwash » Sun Oct 04, 2015 9:25 pm
If you remove the rear spring and lift up the back of the scooter it clears, and if you trim your panel clip at the rear of the frame near side just a little bit then it's easier again, as that gives even more room for the tyre to get past.
Then you can leave the torque wrench at home.
Captain Pugwash
Re: hand pump
Postby Scooterlam » Sun Oct 04, 2015 10:23 pm
Get some compressed air canisters,
Ive got a series one with a modified clip and its a real pain in the ass.
I have the panel off a lot more than I change a wheel.
http://www.ebay.co.uk/itm/10-x-16g-Thre ... 2804d57842
Scooterlam
Re: hand pump
Postby bike grim » Mon Oct 05, 2015 7:32 am
I use a CO2 pump bought for about 10 quid from a cycling shop that uses the canisters as per the link above. Its small enough to fit in a pocket. Used several times on road side when had slow punctures (even tubeless tyres puncture) and 1 caninster gives about 20 psi. So I carry a few.
Re: hand pump
Postby Rich Oswald » Mon Oct 05, 2015 1:00 pm
Halford's hand pumps, fit in the toolbox and do the job fine,
Re: hand pump
Postby Scooterlam » Mon Oct 05, 2015 2:54 pm
Rich Oswald wrote:Halford's hand pumps, fit in the toolbox and do the job fine,
But canisters are so much cooler, and you can smuggle your hippy crack. :lol:
Scooterlam
Re: hand pump
Postby MickYork » Mon Oct 05, 2015 7:17 pm
fit a battery and carry an electric one.
Re: hand pump
Postby HxPaul » Wed Oct 07, 2015 3:14 pm
Warkton Tornado No.1 wrote:TBH I was confusing the panel latch method with the Series III.
Its not superior knowledge - its just the way I've always done it.
