by Chewyboy » Mon Sep 28, 2015 10:32 pm
Hi everyone
My Li 125 series 3 is going back together nicely. After putting the engine in I put on the clubman exhaust and bolted everything up, fine, except I noticed that the seam on the exhaust is touching the head cowling. Wondered if this is normal or not?
Thanks in anticipation.
Chewyboy
by Tractorman » Tue Sep 29, 2015 8:28 am
Was on my AF clubman, just have to grind/file a bit off the cowl not the exhaust or you'll open up the seem.
by Warkton Tornado No.1 » Tue Sep 29, 2015 1:38 pm
If your head cowling is pristine, you may be reluctant to grind/file it, or ding it with a ball pein hammer. The same for your exhaust.
You might be better off to remove the cowling & fit a shorter 'long' M8 cylinder head nut. That's where I would grind off excess material if necessary.
Users browsing this forum: Baidu [Spider] and 90 guests
