axle nuts coming loose
Postby terryj » Sun Sep 20, 2015 11:13 pm
since fitting dampers on front of scoot i find that the axle nuts are coming loose and need tightening on a regular basis (its the bolt on lower mounts)
any answers apart from using lots of thread lock
terryj
Re: axle nuts coming loose
Postby coaster » Sun Sep 20, 2015 11:21 pm
I have had them come loose on both my scoots but they have stayed tight since which would indicate that I hadn't tightened them fully the first time. The washer on the outside of the link fits into a recess and you can't see if they have seated properly with the lower mount bracket in the way. The last ones chose to come loose when I was negotiating the cobbled and streets of the Hague a few years ago, took me a while to realize it was the scooter not the roads :oops:
Postby HxPaul » Mon Sep 21, 2015 10:30 am
If they're after market stainless nuts,there not nylocs like the original nuts and they will come loose.I use these nuts and after I fit them I have to put blue loctite on the threads.If they are the originals they might not sit deep enough to reach the nyloc part with you fitting the bolt on damper bracket.
Postby hullygully » Mon Sep 21, 2015 10:36 am
if you've used damper plate brackets instead of 175/200cc disc links then most likely the nyloc part of the nut ain't reached the axle to lock on :o :o :o :o very scarey!!! probably wiser to fit 2 x half nuts & lock them together 8-)
Postby Adam_Winstone » Mon Sep 21, 2015 1:54 pm
Bearing seating through use?
Postby terryj » Tue Sep 22, 2015 10:33 pm
Adam_Winstone wrote:Bearing seating through use?
sorry dont understand what you mean there
terryj
