Why o Why
Why o Why
Postby jonno » Thu Aug 20, 2015 4:26 pm
Do I keep believing manuals.Rushed out to buy 81 link chain to fit 15/48 sprocket,as stated it stickys manual ,(not stretched),and on the shop website I got it from....and it doesnt fit nowhere near. :evil: :evil: Gonna fork out for one of those sprung top guides.
jonno
Re: Why o Why
Postby jonno » Thu Aug 20, 2015 4:41 pm
Not a sprung one perhaps a Gran Turismo type one.Suggestions?
jonno
Re: Why o Why
Postby Stevepshipley » Thu Aug 20, 2015 8:46 pm
I used a quality pull down one supplied by Corrado on here. Can't remember make but quality kit.
Stevepshipley
Re: Why o Why
Postby Digger » Fri Aug 21, 2015 7:54 am
jonno wrote:Do I keep believing manuals.Rushed out to buy 81 link chain to fit 15/48 sprocket,as stated it stickys manual ,(not stretched),and on the shop website I got it from....and it doesnt fit nowhere near. :evil: :evil: Gonna fork out for one of those sprung top guides.
I'd look at your set up - 15/48 is in range for an 81 link chain.
Digger
Re: Why o Why
Postby jonno » Fri Aug 21, 2015 11:11 am
Digger I have an 81 link chain it doesnt fit,the rear sprocket is 5mm off centre,no way will I get the spider in.An 82 is too long,amazing what difference 1 link makes.Ive counted the links to make sure loads of times.Why does it always happen to me? :D
jonno
Re: Why o Why
Postby hullygully » Fri Aug 21, 2015 12:51 pm
get a spring loaded one from chiggy
Re: Why o Why
Postby jonno » Fri Aug 21, 2015 1:55 pm
Even with a push down guide,would the slack in the 82 chain be too much?
With 81 link chain the recommended one
With 82 link chain
The difference between 81 and 82 links,doesnt seem to relate to the difference between them when fitted.
jonno
Re: Why o Why
Postby Wack » Fri Aug 21, 2015 2:26 pm
I like the GT one as you can screw the plate to the casing and use the unique adjustment bolts on the slipper whereas some other like LTH the top plates screw can be under the chain.
Re: Why o Why
Postby Digger » Fri Aug 21, 2015 4:04 pm
jonno wrote:Digger I have an 81 link chain it doesnt fit,the rear sprocket is 5mm off centre,no way will I get the spider in.An 82 is too long,amazing what difference 1 link makes.Ive counted the links to make sure loads of times.Why does it always happen to me? :D
Where did you get the chain from Jonno?
Digger
Re: Why o Why
Postby jonno » Fri Aug 21, 2015 4:21 pm
Got the chain from camlam genuine iwis i hope.
jonno
Re: Why o Why
Postby Warkton Tornado No.1 » Sat Aug 22, 2015 3:52 am
This is why half links exist. Preferably, 'one & a half' links.
The circumferential difference between 81 & 82 is (pitch x 2) = (3/8" x 2) = 3/4" (19.05 mm)
That results in a lot of slack to take up.
Re: Why o Why
Postby jonno » Sun Aug 23, 2015 2:49 pm
Thanks Tornado good info.
jonno
Re: Why o Why
Postby Nelly » Sun Aug 23, 2015 7:15 pm
I fitted a GT chain tensioner in my engine, works well in either push up or pull down setting.
Nelly
Re: Why o Why
Postby jonno » Mon Aug 31, 2015 11:45 am
Put push down tensioner in place,worried by the angle between sprocket and the tensioner,is it too much,also is it normal to have to undo the nylon block to get to the top fixing bolt? Also bit concerned about having to remove the bottom chain guide to get the tensioner to fit.
jonno
Re: Why o Why
Postby Warkton Tornado No.1 » Mon Aug 31, 2015 7:51 pm
Personally, I don't use the bottom chain guide, nor have I done so since the advent of chain tensioners made of plastics, rather than rubber. I doubt anybody in competition uses them either, & that's where the loading would show a problem, particuarly down changes.
I've previously commented on this Forum (somewhere!) about using 'one & a half links' as if you don't, what you get is as your image.
However, if all is tight in there as in fasteners, I don't think you need to be concerned.
I hope that helps.
Re: Why o Why
Postby rossclark » Mon Aug 31, 2015 8:43 pm
I suspect that not everyone has the skill or confidence to split a chain and add links, especially one they just spent 30 odd quid on. Maybe it would be worth someone writing a quick 'how to' for JetSet?
To answer the question about having to remove the plastic part I believe that it's not unknown to have to remove it to tighten the screws when using it in pull down configurations.
Re: Why o Why
Postby Captain Pugwash » Mon Aug 31, 2015 9:44 pm
rossclark wrote:I suspect that not everyone has the skill or confidence to split a chain and add links, especially one they just spent 30 odd quid on. Maybe it would be worth someone writing a quick 'how to' for JetSet?
I could tell you how not to do it, I fitted a half link assembly without any of the correct tools many years ago.
I used a toffee hammer and a steel block and hammered the hell out of the rivets till it looked right (Ish) this was an old Italian stretched 80 pitch chain with a half link added.
It did stay together and it never broke, but all the time I rode it I was never ever 100% confident and the faster I went the less confident I was :lol:
It's the only time I've ever riveted a Lambretta chain and I'd never do one again unless I had the correct tools for the job.
Captain Pugwash
Re: Why o Why
Postby Wack » Tue Sep 01, 2015 10:14 am
I've done the same and never had a problem, the art is to mushroom the pin just enough to prevent the links binding and prevent the pin pulling out. In reality the pin is being pulled in the chains direction of travel, not sideways. Motorcycle chains come with a soft link that allows you to peen it and look at the power put through them.
Re: Why o Why
Postby Warkton Tornado No.1 » Tue Sep 01, 2015 10:44 am
As far as any technical writing that helps, I'm happy to oblige. For now, with acknowledgement to Renolds for the images:
Anybody familiar with the late Dave Webster's invaluable manual will be aware that he advocated that connecting any link to a chain should be done with rivetted connectors.
Chains joined by that method are the only type that I've known to fail! To be fair, I have 'inherited' other peoples' attempts @ making chains & often they have been over-zealous in grinding the heads of the rivets & always managed to have ground the link face in the process. On the contrary, I have used the 'spring clip connecting link' type in even number link chains & two in odd number link chains without issue! The springs need to be fitted facing the cover & with their closed end going forward in the direction of the chain travel (ACW)
I hope this helps
Re: Why o Why
Postby rossclark » Tue Sep 01, 2015 3:18 pm
I think this is the sort of spring clip you're referring to (and I know this one is back to front - but it's the only pic I could find) -
