Body panels
Body panels
Postby Parky00717 » Tue Aug 11, 2015 11:20 am
Hello all,
I'm new to the lambretta so please forgive my noddy questions (there will probably be many more to
Come!)
I'm just starting a restoration of a Spanish jet 200 and I have started from just a frame tube.
I have been doing as much research as I can before starting anything, can anyone tell me are the body panels interchangeable between series 3 models?
I have found a few bits to start with but its the frame loop that I'm really struggling to find.
Many thanks in advance
Parky00717
Re: Body panels
Postby rossclark » Tue Aug 11, 2015 10:47 pm
Broadly, the Jet is based on the LI special / SX so most S3 parts should fit.
Things like legshields you need to get the right ones for your frame chrome ring or non etc. Spanish panels are a little wider at the top to fit round a slightly wider tank.
Sticky's book should help.
Re: Body panels
Postby Parky00717 » Tue Aug 11, 2015 11:56 pm
Thanks Ross,
From what I've read so far it is chrome ring but I will keep researching.
It's mainly the frame loop I'm wondering about as finding one is like rocking horse sh1t so if they are mainly the same then at least if I do manage to find one then there is more chance of it being compatible.
Thanks for your help
Parky00717
Re: Body panels
Postby ToBoldlyGo » Wed Aug 12, 2015 3:50 pm
There will be differences in the loop between that and an Italian one, depending on the age. But, they're only really cosmetic and won't be seen when the seat is down.
Re: Body panels
Postby Digger » Thu Aug 13, 2015 7:48 am
GRP will do you a fibreglass frame loop.
Top bloke as well.
http://www.grpscooterparts.co.uk/
Digger
Users browsing this forum: Google [Bot] and 51 guests
