Carb questions
Carb questions
Postby Nbowe » Sat Aug 01, 2015 10:57 pm
Want to run a 24mm delo Phbl on a standard Indian gp200.it doesn't fit the standard manifold with carb rubber I have.
Do I need to change the manifold or can I get a carb rubber that will fit.which manifold do I buy and also what jetting should I use with a clubman exhaust.cheers
Nbowe
Re: Carb questions
Postby rossclark » Sat Aug 01, 2015 11:36 pm
I'd think you'd need a specific maifold for that carb.
The standard carb is a solid mount and the PHBL will be rubber as you said.
