Hi All,
I can get my barrel bored to 175 on my GP 150. What piston would I use, would I be able to use the same con rod ,thinking will the small end fit, what other mods would I expect to have to do.
Stag
Adam_Winstone wrote:FYI - AF will supply a good quality Mahle thin ring conversion piston and do the rebore for a VERY REASONABLE sum, and supply a new 175 head for less than it will cost you to have your 150 head machined to suit the increased bore size (needs to be addressed).
