Li 150 cyclinders
Li 150 cyclinders
Postby Triffid » Sun Jul 19, 2015 11:03 am
Hi all
I'm a rare contributor to the forum although a regular reader of its posts. I just wish to check with members something that I think I know the answer to but would like confirming. Basically, is there any real differences between a Series 2 150 cylinder/piston and a Series 3 150 cylinder/piston? Are they, in effect, interchangeable? Thanking you in advance
Triffid
Re: Li 150 cyclinders
Postby hullygully » Sun Jul 19, 2015 11:23 am
there is a differance, keep the series II assy together, as well as the series III assy, DONT mix & match as pistons , porting etc are way different :shock:
Postby Triffid » Sun Jul 19, 2015 8:53 pm
Thank you, Hullygully. I suppose what I was seeking was whether a barrel/piston assembly off a Ser 2 could be used straight on to a Ser 3 - which I gather, it could :D
Triffid
Postby Knowledge » Sun Jul 19, 2015 9:40 pm
Yes, interchangeable.
During the series 3 production, the porting was improved to give slightly more power, with the SX and DL 150's having the best holes. Having said that, even the DL 150 won't rip your arms out.
Postby Triffid » Sun Jul 19, 2015 10:47 pm
Thank you, Knowledge. Input much appreciated :D
Triffid
