solostax wrote:There seems to be a few problems that are apparent:
1/ Can operating /observing the strobe and holding the drill be accomplished single handed?
2/ Is, even a powerful drill capable of taking the revs higher than low/mid rev range?
3/ Because operation rotation is clockwise, would it be necessary to fully torque up the flywheel nut to prevent the drill from undoing the flywheel between every adjustment? This would require the extractor to be used .
Meds wrote:Have you considered the dynamic balance between the motor and the engine
Using an electric drill allows the prime mover ( drill) to float to the engine and you have control over the alignment, and therefore the vibration.
A fixed engine-motor configuration will require some sort of flexible drive otherwise the imbalance will be taken up in the bearings of the motor and engine.
On a much simpler note
Some modern bench grinders have flexi drive connections and standard 240v speed controller may do the trick.
Try googling pedal operated speed controllers
