Ignition
Ignition
Postby Kelly » Sun Jun 21, 2015 8:32 pm
Can you oil an ignition switch if so which oil should be used , its a original switch
Kelly
Re: Ignition
Postby Captain Pugwash » Sun Jun 21, 2015 8:36 pm
You can WD40 is good but you can also buy electrical contact sprays that are designed to do it better.
Captain Pugwash
Re: Ignition
Postby Kelly » Sun Jun 21, 2015 8:47 pm
Wd40 is that not more of a cleaning product , dont want to take out any oil / grease that still in there out , ill look into the electical oil
Kelly
Re: Ignition
Postby Wob8s68 » Sun Jun 21, 2015 10:40 pm
Wd40 is penetrating oil , don't use that , you need lubricating oil !
Wob8s68
Re: Ignition
Postby Donnie » Mon Jun 22, 2015 9:37 am
I've used this to good effect in the past
http://www.maplin.co.uk/p/servisol-supe ... 00ml-jp17t
Donnie
Re: Ignition
Postby Kelly » Mon Jun 22, 2015 7:07 pm
Thanks for the help
Kelly
