by Revvers » Wed Jun 03, 2015 12:09 pm
Hello. Rushing to put my new disc spindle on, I omitted to put the 2 nut spacers on. Subsequently, I've overdone the dome nut, actually going through the dome! Now I can't get the bloody nut off. The spindle turns as I try and I can't get the wheel out. Any tips?? I'm going to try and hold the other end trying not to mess the thread up. Should I try a little heat on the nut? Or do you think I'll have to cut the bugger off?? Cheesed off at my stupidity. Won't rush things again!!
Revvers
by dickie » Wed Jun 03, 2015 12:39 pm
Hold the other end with mole grips but with some copper or aluminium in the jaws.
by Covboy » Wed Jun 03, 2015 2:43 pm
You could put 2 nuts on the good end and tighten them together so they lock. If the nuts you have are too wide to fit onto the thread , file them down. I used this method to extract a casing stud
by Revvers » Thu Jun 04, 2015 6:35 pm
Thanks lads. Removed using the mole grips. Phew!
Revvers
Users browsing this forum: No registered users and 83 guests
