front wheel back plate
Postby kennystag » Sat May 23, 2015 1:23 pm
Hi All,
I have lost the plot with this front wheel back plate on my GP. Can anybody give me a diagram how to rebuild the back plate back on to the hub, not the shoes, and where all the washers go, any help will be appreciated.
Stag
kennystag
Re: front wheel back plate
Postby petemaisey » Sat May 23, 2015 2:09 pm
Would the exploded diagram of the front hub on the Scooter Restorations web site be of any help?
Pete
petemaisey
Postby kennystag » Sat May 23, 2015 2:18 pm
Many Thanks Pete,
I had a look at Scooter Restorations web site, but does not show where the washers go on the rebuild.
Regards
Stag
kennystag
Postby grandpa » Sat May 23, 2015 4:35 pm
Hi Kenny,
For safety sake make sure the axle nut washer (item 15 sec 9 of Scooter Restorations sec 9 wheels brakes tyres) fits in the recess on the fork links .See page 44 Sticky's second edition,removing front wheel....Good luck with your MOT
Grandpa
grandpa
Postby kennystag » Sat May 23, 2015 6:36 pm
Hi All
In picture 1 do you know if there is a washer goes between the spindle and the forks?
In Picture 2 Is there a washer that goes between the spindle nut (not the dome nut) and the forks?
In picture 6 Again is there a washer between the spindle and back plate?
Your help would be very much appreciated. I want to get it right for safety sakes. My mind was wandering when I stripped it probably too much cappicino lol
Stag
kennystag
Postby kennystag » Sat May 23, 2015 6:38 pm
Sorry meant to say when I fitted the new back plate it is rubbing somewhere and that was it tried without the shoes just wondering if anybody else had the same problem, maybe badly made
Stag
kennystag
Postby Wack » Sun May 24, 2015 10:01 am
Paint in the hub groove and on the backplate can cause rubbing. Fitting a shim on top of the internal spacer will move the backplate away from the hub. There is normally a thin washer under the backplate inner nut.
Postby kennystag » Sun May 24, 2015 10:22 am
Many Thanks Wack,
Do you know if there a washer that goes on top of the nut in the third pic.
Stag
kennystag
Postby Wack » Sun May 24, 2015 11:00 am
Only a thin one under just to stop the nut biting into the backplate but not that important. If you fitted a thick one it will move the hub over in the forks.
Users browsing this forum: No registered users and 149 guests
