Front Hub
Front Hub
Postby Alex_amd2001 » Tue May 19, 2015 1:25 pm
Hi Everybody,
When I spin my front hub (drum type) there's a little bit of side to side movement as I look face on to it, suggesting it's slightly buckled? Is this normal/acceptable? Bearings etc are all new as is the wheel rim. Can anybody recommend an aftermarket replacement? Are SIL one's any good? Cheers Alex.
Alex_amd2001
Re: Front Hub
Postby peejay » Tue May 19, 2015 11:24 pm
some hubs will show this slight movement, does it handle and brake ok?
Re: Front Hub
Postby Alex_amd2001 » Wed May 20, 2015 8:31 am
Brakes fine, not had too much of chance to test the handling though...
Alex_amd2001
Users browsing this forum: Baidu [Spider] and 100 guests
