Throttle tube
Throttle tube
Postby bricky36 » Sun May 17, 2015 12:12 pm
Hello
The throttle tube is rusted on my TV headset.
Is there a way to get this off without damaging headset.
Tried heating, just will not move.
Any ideas
bricky36
Re: Throttle tube
Postby petemaisey » Sun May 17, 2015 1:30 pm
Have you a Dremel? If you can slit most of the tube and prise it apart, the bit you can't get to with the cutting wheel will probably surrender. If not you certainly will get some penetrating oil into the remains.
Pete
petemaisey
Re: Throttle tube
Postby bricky36 » Sun May 17, 2015 1:54 pm
I dont have a Dremel (Yet).
I have sprayed loads of wd40, to no avail.
Do have grinder, but chances are I would go straight through, then be in a world of trouble.
Just read something about vinegar, maybe try soaking it in that.
But getting a Dremel does seem the way to go.
bricky36
Re: Throttle tube
Postby petemaisey » Sun May 17, 2015 2:21 pm
You can also split it by cutting a spiral slot using a junior hacksaw.
Pete
petemaisey
Re: Throttle tube
Postby bricky36 » Sun May 17, 2015 3:25 pm
Done it!
Cut a few slits with junior sprayed more wd40 and hey presto.
Thanks for help.
bricky36
Re: Throttle tube
Postby missing lynx » Mon May 18, 2015 7:59 pm
try soaking it overnight in cheap full fat cola
