If my scooter needs lots of revs and a bit of clutch slipping to pull away smoothly, what carb settings should I be looking at changing?
It's an RT195 with a 30mm PHBH
MickYork wrote:what is your carb' jetting ? be sure to check the plug if you drop the pilot jet (could run too lean).
Users browsing this forum: Baidu [Spider] and 95 guests
