rust in my tank...
rust in my tank...
Postby simmo » Mon Apr 20, 2015 9:24 pm
Got a new long range tank , had it carbon dipped (top job) but when I received it I noticed that I had a little rust build up. Chucked some gravel in it, wrapped it in a duvet and threw it into the tumble drier for two hours ( for the record, a diablo tank wrapped in a 5 tog single duvet will fit into an average sized tumble drier! :lol: :P )- swilled it through with fairy liquid and hot water.
99% sorted, I just have a very light "speckling" left. Ran some petrol through it and all seems ok.
Trouble is its bugging me- do I
a) leave it and see how it goes.
b) seal the tank with petseal or an equivalent.
c) do the electrolosis thingy with the bolt as a sacrificial anode.
Your thoughts are very much appreciated..
simmo
Re: rust in my tank...
Postby Norrie Bodge » Mon Apr 20, 2015 9:29 pm
fit it m8, then add an inline petrol filter with a magnet inside
like this - http://www.ebay.co.uk/itm/Universal-Mot ... 4ae1b4e8fc
Norrie Bodge
Postby simmo » Mon Apr 20, 2015 9:33 pm
cheers for that Norrie, not used an inline filter for a while! any problems with air bubbles with these type of filters?
simmo
Postby Norrie Bodge » Mon Apr 20, 2015 10:22 pm
just been C2C with one fitted
My my tank was like yours still slight traces of rust !!
470miles done since fitting & no issues m8
Norrie Bodge
Postby Mel K » Tue Apr 21, 2015 9:54 am
I've put 3 betting shop magnets to the underside of my Diablo tank, just next to the petrol tap.
My float bowl has always been spotless when checking it sinse . I like to think its the magnets doing their job!
Oh, and I've done around 8000 miles with them .
Mel K
Postby Tractorman » Tue Apr 21, 2015 12:03 pm
POR 15 is excellent tank sealer I have used it twice and recommend it.
Postby simmo » Tue Apr 21, 2015 5:24 pm
Thanks for the replies gents, much appreciated.
simmo
Postby burnside » Wed Apr 22, 2015 7:49 pm
Just as a side note, Fairy liquid contains salt so probably not the best cleaning fluid to get rid of rust
burnside
Postby sherpadean » Wed Apr 22, 2015 8:50 pm
PQR 15 sorted my tank when I was struggling with the dreaded 'rust' - having used Phosphoric acid unsuccessfully several times.......................can't wait to start re-assembling....................
sherpadean
Postby Digger » Thu Apr 23, 2015 5:43 am
Once you got rid of all the loose surface rust your petrol and oil does a pretty good job of keeping it at bay.
Digger
