Kickstart issue
Kickstart issue
Postby Nbowe » Fri Apr 10, 2015 11:53 pm
Hi fellas,I'm new here. Can anyone help me here.have had the chaincase off my gp and now I have put it back the kickstart falls to the ground when riding along. I did undo the clutch cable and have reconnected it.the scoot kickstart fine but the gears are also bit stiff now(they were fine before) is it a clutch adjustment problem? I have also replaced the brass plunger on clutch arm.could the problem be the kickstart not positioned correctly when replacing the chaincase????? Thanks in advance
Nbowe
Re: Kickstart issue
Postby Wack » Sat Apr 11, 2015 12:13 am
The spring keeps it tensioned,so it's either broken or the ends are not fitted in the casing or kickstart shaft.
Re: Kickstart issue
Postby Nbowe » Sat Apr 11, 2015 8:33 am
cheers,looks like I'll be takin it to bits again....
Nbowe
