by Wack » Wed Apr 01, 2015 3:53 pm
Is anyone running an NK Rally pipe on a Ser2 and did you have to cut the rear footboard? Pics would be nice, thanks
by Toddy » Wed Apr 01, 2015 8:56 pm
I have an ADS pipe on my series 1 and yes I had to trim my rear footboard but I also did on the franspeed on my series 2 I'll see if I can find a picture , I also changed the rear mounting bracket on the casing to the 4 stud MB one
by Wack » Fri Apr 03, 2015 10:31 pm
Well the NK doesnt fit a Ser 2 ,not without some cut n shutting anyway.The stinger pipe touches the side panel and the footboard needs cutting after re-locating the stinger and end can to clear the panel handle.
by Toddy » Sat Apr 04, 2015 7:45 am
Wack wrote:Well the NK doesnt fit a Ser 2 ,not without some cut n shutting anyway.The stinger pipe touches the side panel and the footboard needs cutting after re-locating the stinger and end can to clear the panel handle.
Oh dear not good then , like I said mine was an ADS pipe which look very similar to the NK but must be different mine is closing to the panel handle but not the main section although I did have to trim the rear foot board I'll take a pic and load today while I'm out on it .
