JETEX wrote:The floats are notorious for sticking. Remove the float and rub the edges where the pin goes through on some fine Emery paper to give the float some side to side movement when it's fitted. You may have to enlarge the hole in the float for the pin, as these can sometimes make the pin a tight fit in the float preventing it from swivelling correctly. All learnt from experience !
