engine/wheel alignment
Postby simmo » Sun Mar 29, 2015 1:09 pm
Been out in the garage tinkering,(like you do) and its come to my attention that when I look at the back of my bike the wheel/engine isn't in line with the frame.On closer inspection I found that the head cowling is considerably closer to the right hand side than the left- looks to me like the whole lump is at an angle! silent block on the r/h side doesn't look right- ie not level and the holes aren't as they should be, looks almost like its sort of given up.
The bike rides ok, no vibration issues etc. Any one have any idea where I should be looking to "square" the engine up? silent blocks ? cones? both?
Jet 200 by the way.. ( well it was once.... :lol: )
simmo
Re: engine/wheel alignment
Postby rossclark » Sun Mar 29, 2015 7:50 pm
Sounds like the engine mounting block has gone , common for the kickstart one to go. You need to replace them.
Cones don't tend to be a problem unless you've got offset ones that have slipped.
Postby simmo » Sun Mar 29, 2015 9:15 pm
thanks for the reply ross, next question- any recommendations ? BGM?
simmo
Postby rossclark » Sun Mar 29, 2015 10:31 pm
Your Jet should originally have had the short Li style mounts which are better for handling but transmit more vibration. I'm guessing when you mentioned holes you already have longer mounts? This might depend on the state of tune of your engine and the balance of your crank. Most folks fit the longer ones now unless going concourse. They flex a bit more but transmit less vibration, though there's varying opinions on that.
BGM / Scootopia are both supposed to be good. Genuine SIL can also be OK trouble is finding genuine - SR a good bet here, there's plenty faked SIL a stuff out there.
Postby simmo » Sun Mar 29, 2015 11:07 pm
thanks again Ross, tuned rb225 motor, bit of a flier.... heard the same ref BGM and scootopia.
simmo
Postby Nelly » Mon Mar 30, 2015 11:10 am
I've just fitted the BGM ones to my Jet engine, ordered direct from Scooter Center in Germany. With some help from Scotty and his collection of tools, I must add!
I was having some serious vibration issues last year and the old mounts were about shot. I also fitted offset cones as the reed valve body was fouling the frame too. All seems well now.
Nelly
Postby simmo » Wed Apr 01, 2015 6:46 pm
Good skills Nelly, that's the route i'll be going down..
simmo
