Series one rear light
Postby Scooterlam » Sun Mar 15, 2015 2:04 pm
On a series one and possibly two.
how are the bulbs arranged, i think mine is a non brake light one, 125 speedo blank.
is it brake light one side and tail the other.
also is it possible to get the reflector out.
Scooterlam
Re: Series one rear light
Postby Scooterlam » Tue Mar 17, 2015 9:26 pm
I'll try a different tack,
where do your bulbs go in a series one back light.
Scooterlam
Postby Angry Bloke » Tue Mar 17, 2015 9:37 pm
I've got an S1 rear light on my Spanish S2 and it's the main lamp in the middle and brake light either side ( well that's how I wired it ! )
Angry Bloke
Postby Scooterlam » Tue Mar 17, 2015 11:30 pm
Cheers angry bloke,
Does your lense have a reflector in the red plastic . And does it block much light.
Scooterlam
Postby lammydave » Thu Mar 19, 2015 7:05 pm
the series 1 lights with 3 bulbs had no reflector, all 3 bulbholders were mounted on a rubber base...
http://www.scootopia.co.uk/product/5705 ... r-19283050
similar to this
lammydave
Postby Scooterlam » Thu Mar 19, 2015 8:33 pm
Thanks,
My series one came with a bgm unit that had failed, so I had no bulb holder to work from. I've been making up a home brew
Led jobbie.
I can't get the reflector to budge so I may double up on the tail light to compensate .
For less than £3 I'm well pleased.
My 1960 series 2 UK from New, had no brake light either.
Was there a year when the changed to brake light.
Scooterlam
Postby Angry Bloke » Thu Mar 19, 2015 8:37 pm
Scooterlam wrote:Cheers angry bloke,
Yes it does and no it doesn't block the light .I do use LED bulbs in it though rather than standard festoons
Angry Bloke
Postby JBG584 » Thu Mar 19, 2015 10:04 pm
brake light was fitted on late 1960 mine had the holes but no switch its a April 1960 series 2 I know its right had the scoot from 1960
JBG584
Users browsing this forum: Google [Bot] and 69 guests
