by garynonnah » Sat Mar 07, 2015 5:02 pm
12V Electronic system no battery GP SIL.
just restored scoot...all new gear...
All was working fine with lights, took for lil run with lights on.
just checking her ova, and no lights,well not quite front light is very dim,
and horn is low noise...could it be regulator ? ive checked all connections.
garynonnah
by MickYork » Sat Mar 07, 2015 5:16 pm
Possibly but a dodgy earth would be a good bet.
by garynonnah » Sat Mar 07, 2015 5:53 pm
FOUND THE PROBLEM....BGM LED LIGHTS BLOWN AGAIN....
going back to normal bulb....which just checked and ok...
garynonnah
by Nelly » Sat Mar 07, 2015 5:59 pm
Is this the same bike you were discussing in the other thread, you added some diodes?
What voltage is the regulator pumping out at high revs with the LED fitting disconnected?
Nelly
by garynonnah » Sat Mar 07, 2015 7:05 pm
yes it is....didnt seem to get a constant reading on volts, but it seemed
the brake light circuit blowing , diode overheated,....
But maybe because brake light was on all the time, because i havnt connected up
brake peddle yet....
garynonnah
