by Callummal » Sat Feb 28, 2015 2:05 pm
Hi all what should be the correct spring for a R1 type shock to fit a ser 2 TV 175 thanks
Callummal
by rossclark » Sat Feb 28, 2015 4:14 pm
Without being rude, it depends what you weigh and whether you'll be using it with pillion and luggage or just solo.
by Callummal » Sun Mar 01, 2015 10:53 am
Hi solo and I weigh 14 stone thanks
Callummal
by Wack » Sun Mar 01, 2015 7:16 pm
Most go for a 225 lb spring but I prefer a 180 then use the adjusters to suit.
by Knowledge » Sun Mar 01, 2015 7:36 pm
I am just under 12st, and use the 180lb spring (if this helps)
by gaz_powell » Sun Mar 01, 2015 8:49 pm
10 stone 180lbs always travel on my own with a sizeable bag.
Users browsing this forum: No registered users and 153 guests
