Indian series 3 mag housings anyone tried these
Re: Indian series 3 mag housings anyone tried these
Postby Wack » Tue Feb 24, 2015 6:56 pm
Perfectly ok, the castings a bit rough so needs a file up and although Restos list a 150 version they come with the 200 sized transfer cutout.
Postby Digger » Tue Feb 24, 2015 7:14 pm
+1
Digger
Postby Meds » Tue Feb 24, 2015 7:29 pm
I have fitted one to two different Innocenti engines and they work fine. Like all indian stuff run a tap up the threads, check the fit into the casing(I had to use some wet and dry to make it fit smoothly ) and clean up the castings and they are fine.10mins work.
Meds
Users browsing this forum: Baidu [Spider] and 96 guests
