headset stripped thread
Postby garynonnah » Mon Feb 23, 2015 6:46 pm
HI all.
what is the preferred method for repairing M4 thread for headlight rim on headset.
not enough room to put in a helicoil??
garynonnah
Re: headset stripped thread
Postby terryj » Mon Feb 23, 2015 7:07 pm
think i saw pop rivet the hole then tap the pop rivet
terryj
Postby Nelly » Mon Feb 23, 2015 7:25 pm
On the SX headset the thread is 3mm, I seem to remember.
The threads on my headset top were knackered so I tapped them out to 3.5mm, the size of electrical socket box screws. Any good electrical wholesaler will have a 3.5mm tap.
Not sure if this would apply to all headsets though.
Nelly
Postby garynonnah » Mon Feb 23, 2015 7:54 pm
cheers, its defiantly M4 thread....on a GP....
Looking at different inserts, on web.
garynonnah
Postby gaz_powell » Mon Feb 23, 2015 9:20 pm
I've done a gp not so long ago
Bought the correct size rivnut (m3 or 4) - you can get ss or ali
Drill out the hole to accept the rivnut
Insert the rivnut and add some epoxy glue around it.
worked a treat
Postby mickey c » Tue Feb 24, 2015 1:03 am
I got a lad to ally weld a knackered headset hole. It was huge / knackered and put a blob (techincal term) I then just drilled and tapped a new thread.
mickey c
Postby garynonnah » Tue Feb 24, 2015 6:56 am
CHEERS LADS
Found some self tapping inserts, hopefully should do the job. :o
garynonnah
Postby TS1-200 » Tue Feb 24, 2015 9:34 am
I would be wary of putting any inserts in that require the use of a pop rivet gun, could crack the ally, I have always found the pop rivet head method works quite well, put in from behind
TS1-200
Postby ian i.o.w » Tue Feb 24, 2015 8:00 pm
used rivnut in my gp headset worked a treat
ian i.o.w
Postby garynonnah » Mon Mar 02, 2015 6:32 am
SORTED THE PROBLEM....it was originally M3 thread ....opened up to M3.5 ...sorted
CHEERS
garynonnah
Postby Dimitrios_231 » Mon Mar 02, 2015 9:48 am
Depending on the damage,
brass inserts with thread lock can also work fine.
Dimitrios_231
