series 2 light switch help needed
Postby bjhart » Sat Feb 21, 2015 11:39 pm
Hi
I have used an Indian light switch for many years with intermittent problems, finally sucumbed to fitting a so called original switch I bought a few years ago but the wire colours do not match any of the diagrams I have. Basically there are 2 groups of wires, one into the the main connector block in the headset and one for the headlamp connector block.
Main connector block
Green/white
Black/white
Orange
Red/white
Headlamp block
Red
Blue
White
Any suggestions where they might go?
bjhart
Re: series 2 light switch help needed
Postby bjhart » Sun Feb 22, 2015 5:38 pm
Well I've sorted the wiring, judging by the length of the wires I think it might actually be a 3 wheeler switch, so I will need to shorten all the wires. Anyway it was all working then the aluminium piece that holds spring and ball that locates the main switch disintegrated.....Anyone got an old broken switch they don't need it's the type that has the screw on lever for the switch....
Barry
bjhart
