So with a replacement sender FOC
LateAgain wrote:Cheers lads. I was thinking of a route thru the head Coaster but do like the idea of the sensor sitting over the top of the plug and resting on the metal section held in place with pipe, less fettling to be done. Would this in effect though be measuring the heat of the plug as opposed to the head temperature?
When speaking to Skydrive they said the two wires required 'welding' together but not conventional welding so resupplied one. Bloody nice bloke.
coaster wrote:If you are going to use the sensor under the plug (best place for it tbh) you need to modify the head by cutting a channel to allow the sender lead to lay flatter. However, the rings are not very robust and don't survive many plug removals as they are made of very soft metal. I read recently that the ring can be placed over the porcelain insulator so that it is in contact with the metal part of the plug and held tight against it with a short offcut of petrol pipe. I've not tried this myself yet but it was said to be almost as effective as under the plug. As already mentioned, some people bolt the sensor to a fin which will work but the readings you get will be significantly lower and more importantly, will be slower to react to temperature changes.
jonashford wrote:coaster wrote:.........................I read recently that the ring can be placed over the porcelain insulator so that it is in contact with the metal part of the plug and held tight against it with a short offcut of petrol pipe. I've not tried this myself yet but it was said to be almost as effective as under the plug........
Did anybody read the sip speedo article in Jetset???? Very good idea to sit the sensor on top or the plug next to the metal that contacts the head, secured with a piece of pipe, very simple and it works
