TV cable brakes/ tyres?
Postby 911hillclimber » Wed Feb 04, 2015 7:03 pm
Keeping the stock configuration, but my flat clean disc could do with a skim and fresh pads.
Any opinions on pads? The TV will be a occasional weekend run-out scooter, nothing more.
In my other interests, usually the most expensive ones are the best. Is this so?
Is reverse-pull really worth it? Back in '67 I had this on my TV3 175 and it worked ok rather than great. World was a different place then though.
To tyres, I want white walls BUT with the minimum of white, more white band, classic tread look, standard size.
Again, are the most expensive the best? I am thinking to fit 'winter' tyres and use them all year round for wet grip, or is this stupid?
Bit of guidance needed as usual please.
Graham.
Bit like this:
911hillclimber
Re: TV cable brakes/ tyres?
Postby pirate pete » Wed Feb 04, 2015 10:14 pm
I use the reverse pull set up and find it very beneficial. Also I recommend sintered brake pads. Newfren work fine for me. My scoot front brake gave great readings on the MOT Station brake rollers and on the road good feel and inspire confidence. Pete.
pirate pete
Postby dickie » Wed Feb 04, 2015 10:52 pm
That effing awful seat will act as a windbrake so you don't need to worry unduly about friction coefficients
Postby 911hillclimber » Wed Feb 04, 2015 11:34 pm
:lol:
Thank you both for fact and a good imagination, made me smile!
I've seen those pads. I have standard rear shoes (new), but better at the front is a benefit.
Also notice Scoot Rest have a 20% off offer...
911hillclimber
Postby Dimitrios_231 » Sat Feb 07, 2015 10:39 am
Reverse pull it ;)
Dimitrios_231
Postby 911hillclimber » Sat Feb 07, 2015 6:11 pm
Yes, I've made my mind up to do this 'mod' now I've read and remembered how simple the change is!
The detail on your front assembly looks great, better pull my socks up... :cry:
Thanks,
Graham.
911hillclimber
Postby Dimitrios_231 » Sat Feb 07, 2015 8:00 pm
Thank you,there is a lot of useful information about them in the forum,you won't have any problems :D
Dimitrios_231
Users browsing this forum: Google [Bot] and 69 guests
