by parky » Mon Jan 26, 2015 2:49 pm
I notice in Sticky's it recommends fitting a fast flow fuel tap even to standard engines. I have a standard 200 engine so what is the advantage of fitting the fast flow tap?
and does it mean you use more fuel than if you stuck to the original?
parky
by HxPaul » Mon Jan 26, 2015 3:56 pm
You'll still use the same amount of fuel,but you wont risk the chance of fuel starvation,possibly causing your engine to seize
by 911hillclimber » Mon Jan 26, 2015 5:00 pm
I have just yesterday cleaned my TV 175 III part in cellulose thinners etc to clear the drillings and the long tube filter.
Even cleaned out when you blow down the passages of the delivery side of the block the restriction is huge. no wonder he advises a fuller flow! Is there some deliberate flow restriction in there under the black disc?
A new free-flow tap is better than a seized piston....
911hillclimber
by parky » Mon Jan 26, 2015 5:13 pm
Thank you chaps, it appears the one I have had in the garage for a couple of years deserves to be fitted, so I had better get on with it.
parky
by St George » Mon Jan 26, 2015 6:47 pm
Mate, don't fit a cheap one. Cambridge Lam' sells decent ones and they are only a few pounds.
St George
by Afandy » Tue Jan 27, 2015 10:49 am
Scootopia are doing spot on remades of original ones with a fast flow ....but do know they were out of stock ...but awaiting new ones back in ...Andy
Afandy
