Help Required For Fitting Series 3 Front End (West Midlands)
Postby Gino_Lamberto » Thu Jan 15, 2015 12:30 pm
Hi forumgoers,
could I pick your brains please ?
A 'friend' of mine (apparently) :roll: has let me down regards fitting my new fork links into my new forks.
If there are any workshops or members who want the cash to do the do job for me would you make yourselves known please.
I am in Wolverhampton WV6 so any where in the West Midlands would be a bonus
Many TIA
Gino_Lamberto
Re: Help Required For Fitting Series 3 Front End (West Midla
Postby Noddabodder » Thu Jan 15, 2015 5:35 pm
It's actually a straightforward job Gino, you should give it a go yourself.
Noddabodder
Postby EIBARFAN2 » Thu Jan 15, 2015 8:55 pm
RING NIGEL (07786012342) AT SHELFIELD SO CLOSE FOR YOU ! ;)
EIBARFAN2
Postby Gino_Lamberto » Mon Jan 19, 2015 7:02 am
Morning forum people, sorry about the slow response I have been offline for a week or so. Thanks for the replies, if I am honest I would most likely tackle the job myself, my only stumbling block is that I don't have access to a vice, believe I have tried the job without a vice, and its a non starter haha
Gino_Lamberto
Postby coaster » Mon Jan 19, 2015 8:50 am
Gino_Lamberto wrote:......my only stumbling block is that I don't have access to a vice, believe I have tried the job without a vice, and its a non starter haha
I don't have a vice either, I just use a cheap B&Q type workmate bench, it's not ideal but will hold the forks firm enough to get the job done. You will need a fork spring compressor though ;)
Postby HxPaul » Mon Jan 19, 2015 10:12 am
I've managed to remove and fit springs while the forks were in the scooter using a spring compressor.
Postby Gino_Lamberto » Mon Jan 19, 2015 10:49 am
Ahhhh a black & decker workmate ... simple, why didn't I think of that, and I'm meant to be an engineer haha
Luckily I have all of the tools, I invested in them when I brought the scoot :)
Cheers guys
Gino_Lamberto
Postby Knowledge » Mon Jan 19, 2015 10:27 pm
Good luck. ;)
Postby Gino_Lamberto » Tue Jan 20, 2015 6:51 am
Cheers Knowledge ;)
Gino_Lamberto
