fuel tank
fuel tank
Postby garynonnah » Fri Jan 02, 2015 6:44 pm
just starting to fit tank on gp....new straps and rubber mounts....
Are there any tips on best method of fitting
garynonnah
Re: fuel tank
Postby DaveTomo » Fri Jan 02, 2015 6:52 pm
DaveTomo
Re: fuel tank
Postby garynonnah » Fri Jan 02, 2015 6:54 pm
cheers just been there.....easier said than done....but will get there....appy days
garynonnah
Re: fuel tank
Postby HxPaul » Fri Jan 02, 2015 7:09 pm
When fitting the drip tray and felt ring,I always fit the tray first and then the felt ring,that way the felt ring can be taken out and dried if fuel is spilt.
Paul
Re: fuel tank
Postby dickie » Fri Jan 02, 2015 7:46 pm
I had a nightmare with my drip tray and ended up cutting loads of it away including 2 notches so that the spring clips could clip onto the hole in the frame.
I used the early type fuel tank rubber buffers. I'm not convinced that the drip tray and felt should be used with those type. Anyone wiser than me?
Re: fuel tank
Postby garynonnah » Fri Jan 02, 2015 7:52 pm
cheers guys...will post my outcome.... :?
garynonnah
Re: fuel tank
Postby HxPaul » Fri Jan 02, 2015 8:40 pm
dickie wrote:I had a nightmare with my drip tray and ended up cutting loads of it away including 2 notches so that the spring clips could clip onto the hole in the frame.
Did you make sure that the drip tray sat on top of the tank below the flap opening ? It can be a little difficult to get in,but if you soke it in hot water until its supple enough,it usually goes in without much trouble.
Re: fuel tank
Postby gaz_powell » Sat Jan 03, 2015 2:01 pm
I had to trim trays to get them to fit - even after the hot water method
