Ignition switch
Ignition switch
Postby STFC » Sat Dec 27, 2014 8:28 pm
Evening, I've fitted a new ignition switch to my Dl 150 today and I'm getting no power what so ever out of the ignition switch on the Orange headlight feed.The Brown Live feed into the switch is all good, as are the earth connections and the main bulb.All wiring colours are matched correctly. I have not refitted the old working switch to rule out my theory( but will tomorrow).Am I right in suspecting a dodgy new ignition switch or am I missing a trick, Its been a long day ! The scooter has 12 volt ignition on the Original Italian wiring loom ..
STFC
Re: Ignition switch
Postby dickie » Sat Dec 27, 2014 11:09 pm
Maybe I'm unlucky but I fitted a new one last week and the green and blue wires were swapped.
I'd recommend checking each wire to ALL the others at all switch positions.
A right pain in the arse but necessary.
Re: Ignition switch
Postby STFC » Sun Dec 28, 2014 7:05 pm
As thought the New switch is faulty ..Old cheap switch refitted and all good .... :(
STFC
Re: Ignition switch
Postby gaz_powell » Sun Dec 28, 2014 7:16 pm
can we ask what and the where the switch came from ?
Users browsing this forum: Baidu [Spider] and 83 guests
