Lay shaft O ring
Lay shaft O ring
Postby pip » Fri Dec 26, 2014 5:05 pm
Just wondering if the O ring for a indian G.P. 200 lay shaft can be sourced from any where else besides a scooter dealers i.e. B&Q and what size are they if they can be. I need one asap and if I could get one local it would be a big help rather than having to order one and wait. :shock:
pip
Re: Lay shaft O ring
Postby gaz_powell » Fri Dec 26, 2014 8:39 pm
its 20mm x 2mm if that helps
Postby Tractorman » Fri Dec 26, 2014 9:22 pm
You should get one at most bearing and seal suppliers or hydraulic repair shops.
Postby gaz_powell » Fri Dec 26, 2014 10:20 pm
its a size you often find in o ring kits
Postby pip » Sat Dec 27, 2014 1:50 pm
Thanks, will plumbers ones be ok or will the oil effect them. :?
pip
Postby Scooter Paul » Sat Dec 27, 2014 2:35 pm
As Gaz says any car repair garage will have a box of assorted o rings. I'm sure a friendly mechanic will sort you out a couple. Best have a spare in case it catches as you assemble the lay shaft into the bearing. I always put a smear of grease and twist the shaft as it goes in.
Paul
Scooter Paul
