Speedo drive
Speedo drive
Postby Rich Oswald » Sat Dec 13, 2014 11:26 am
Just changed the speedo ring drive on the S1, what a sod of a job. Had to grind it down on both sides to get it off then to get the new one on (metal) I had to heat it up and use a wooden drift to knock it on. I always wondered what held them on, now I know!
Anyway, the worm, the one I have taken out is shorter than the new one (obviously meant for S3) so will the longer one work ok or do I need to get a short one?
Cheers,
Re: Speedo drive
Postby Rich Oswald » Sun Dec 14, 2014 6:57 pm
Nobody know then?
Re: Speedo drive
Postby Dimitrios_231 » Sun Dec 14, 2014 8:16 pm
Did you buy as a pair?
If yes,use the supplied one.
You need to be very careful when assembling,
it might feel that it rubs,
go gently,use a lot of grease,
after a few miles,remove it, check and repack with grease.
Dimitrios_231
Re: Speedo drive
Postby Scooter Paul » Sun Dec 14, 2014 8:21 pm
I always thought the shorter ones were for disc brake models?
Paul
Scooter Paul
Re: Speedo drive
Postby Rich Oswald » Sun Dec 14, 2014 10:01 pm
Cheers guys, S1's are shorter according to Sticky's manual.
