by Covboy » Fri Dec 12, 2014 2:00 pm
Hi - I am stripping a 1968 Italian SX150 for restoration and the long screws that secure the headlight rim to the headset bottom have sheared.
I wish to retain the original headset therefore will need to remove the broken screws from the lugs and repair the threads.
Does anybody know the correct helicoil size & pitch ?
Is it M3 x 0.5?
by Jono » Fri Dec 12, 2014 2:53 pm
Hi Cowboy
I had the threads on my headset strip and tapped the holes out to 3.5 mm using a tap from B&Q sold for tapping out electrical switch boxes . Then used chromed switch box screws looks like original.
Could be an option as not much metal for helicoil!
Jono
Jono
by Covboy » Fri Dec 12, 2014 4:52 pm
Hi Jono - sounds like a better plan !
by Covboy » Fri Dec 12, 2014 5:29 pm
Ok job done - I centre punched the snapped screw, drilled it out using a new sharp 2mm drill and retapped it using 3mm tap!
S
