Engine Bearing kits
Engine Bearing kits
Postby inch71 » Tue Nov 18, 2014 7:44 pm
I'm doing a full engine rebuild over the winter, due to fitting a new Mugello top end kit.
I've had the scooter for over 5 years, & the lad before me had it rebuilt quite a few years before that. So whilst I've got the engine out, I thought it would be a good idea to do a full rebuild.
As I shall be fitting all new bearings & seals etc. I was just wondering if anyone could recommend where to get good quality bearing kits, containing all the bearings I need. I've seen Mike Phoenix do a kit for £99.99, & Glasgow Lambretta do one for £67.99
There is also a couple of specialist Bearing shops close to me. I thought maybe of taking the bearing numbers from Sticky's book to these, & seeing what price they come out at.
So would I be best to buy the full kit from a dealer, knowing these are the exact bearings for a Lambretta, or would I get the same bearings from a bearing specialist, that I know stock SKF, FAG, INA etc, & would I need to let the bearing shops know anything specific before buying from them.
Any advice will be welcome.
Lee
inch71
Re: Engine Bearing kits
Postby piskie » Tue Nov 18, 2014 11:51 pm
Koyo bearings glasgow do a good price x or shop around
piskie
Postby foremanbob » Wed Nov 19, 2014 9:33 am
The Glasgow Lambretta bearings are all SKF & FAG bearings ;) Not sure that you'll find anywhere cheaper.
foremanbob
Postby rossclark » Wed Nov 19, 2014 6:24 pm
try also bearing boys on line you wont get the rear hub but a lot of the rest are a fraction the price
http://www.bearingboys.co.uk/
Postby dave411 » Wed Nov 19, 2014 7:12 pm
Fit a new lay shaft too.
dave411
Postby inch71 » Wed Nov 19, 2014 9:53 pm
Chiggy at Lambretta Upgrades has sorted me a good deal for all bearings & seals.
Thanks for the replies everyone
inch71
