rev counter in Jetset topic
Postby prog54 » Wed Nov 12, 2014 6:00 pm
I was reading a topic in Jetset about the SIP speedo and rev counter and was surprised to see that at 50mph the revs measured 2100.
With a 185 engine, standard series 2 exhaust and 25ml carb my rev counter at 50mph reads about 5000 and at idle about 1000 revs, are my readings completely wrong. :?
prog54
Re: rev counter in Jetset topic
Postby CHRIS in MARGATE » Wed Nov 12, 2014 6:12 pm
Nope. I read it as well. Got his numbers very wrong.
Postby Norm » Wed Nov 12, 2014 8:14 pm
The whole thing reads just like an advert for SIP, I hope they paid handsomely for it. I've chucked the mag away now, but I've a feeling that the publishers didn't even bother editing SIP's mistakes out of the copy they clearly submitted themselves. Doesn't it mention something about the speedo being for Vespas somewhere in the "article"?
Norm
Postby rossclark » Wed Nov 12, 2014 10:07 pm
There's another article in the latest Jetset which has somebody else's bad experience with it...
I think that's the one being discussed in this thread
I think at 2100 rpm for 50mph, he'd have to have about 2.2 final gearing
Postby carlos fandango » Thu Nov 13, 2014 12:31 am
rossclark wrote:There's another article in the latest Jetset which has somebody else's bad experience with it...
He will have around 2.2 final drive , as hes measured the circumference of his wheel as 3160mm ????? that equates to a wheel diameter of around 1000mm :shock: :lol:
It should work out at around 10mph per 1000rpm, depending on final drive and tyre size :)
carlos fandango
Postby Knowledge » Thu Nov 13, 2014 12:32 am
Norm wrote:I've chucked the mag away now, but ..........
Thanks for your candid comment. :roll:
Postby Norm » Thu Nov 13, 2014 8:25 am
@ Knowledge - you're welcome :)
@ Ross - ah, that makes sense, I haven't received the latest issue yet.
BTW, I'm not bashing the SIP speedo, in fact I've got one which I'm waiting to fit. Just couldn't help but notice the "advertorial" nature of the original speedo article in the mag. But I apologise, that's going away from the original topic, which just sounds like a genuine typo.
Norm
Postby Timexit17 » Thu Nov 13, 2014 12:20 pm
quite clear to me he doesn't have a resistor type plug fitted either (or didn't initially) and I'm guessing that was his main issue.
Timexit17
Postby peejay » Thu Nov 13, 2014 1:00 pm
Norm wrote:Just couldn't help but notice the "advertorial" nature of the original speedo article in the mag.
which article is this then, just to be clear.
Postby Knowledge » Thu Nov 13, 2014 1:43 pm
Norm wrote:@ Knowledge - you're welcome :)
Norm,
Please feel free to contribute to Jetset.
We contributors and the editor always welcome articles from new blood. I promise I won't be quite as dismissive as you appear to be of our efforts to create the club's bi-monthly magazine. :(
Postby Norm » Thu Nov 13, 2014 3:46 pm
Wow, someone's got the wrong end of the stick I think!
The mag's great, just that one article read like an advertorial, which I'm certain it was. If it was written by an LCGB member, I don't think it would mention Vespa. I think it was lifted straight from SIP's blurb, and SIP/LCGB forgot to change one of the references to Vespa (for which the speedo was originally made, and the article written presumably).
Norm
Postby prog54 » Thu Nov 13, 2014 4:55 pm
Hi guys
Thanks for the replys, apart from the criticism and grumbles am I to assume that my rev counter which does measure approx. 1000 revs per 10mph is correct.?
cheers
Terry
prog54
Postby CHRIS in MARGATE » Thu Nov 13, 2014 6:16 pm
+ or - a little bit depending on gearing.
Use the excellent gearing calculator available on the net.
10.2mph/1000 revs at 4.9:1 with my 400x10 tyre on my scoot and about 9.8 with 350 x 10 at about 5.2:1
Postby scootergirli » Fri Nov 14, 2014 12:16 am
Hi Norm
The 'advertorial' you mention from issue 191 is exactly that, and I had hoped that with the opening lines of:
" The guys at SIP have kindly sent us for your perusal some information about the SIP speedo range, so hopefully a few questions, that some may have, will be answered here."
people would be able to work it out that this was written by the SIP team and the other giveaway would be that the name at the end end of it was:
Ralf Jodl - (aka, (one of the) founders and managing director of the SIP Scootershop GmbH)
Hope this clears up any confusion for anyone, I'd also like to say thanks to Ron Wood, for his experience of the SIP speedo (Issue 192) in response to SIP's info, as it's always good to see opposing opinions.
And apologies for the error with the dirty VESPA word, oops I did it again! 8-)
in the words of my Latin tutor, Mr Hobbs “Errare humanum est.” I think Alexander Pope may have expanded on it!
Thanks to all who contribute it is very much appreciated and hope that more members' continue to do so.
Regards
Linda
:D
scootergirli
Postby Norm » Fri Nov 14, 2014 8:01 am
Thanks for the clarification Linda - I hope the speedo's as good as they say it is :)
Keep up the good work!
Norm
Postby Digger » Fri Nov 14, 2014 12:52 pm
To err is human; to forgive, divine.
Alexander Pope
8-)
Digger
