Handlebar gearchange
Postby JETEX » Sat Nov 01, 2014 10:30 pm
I'm rebuilding my LiS / TV type headset. I've fitted the throttle side switch housing with the two shim type washers, then the plastic plug in the end of the handlebars, followed by the throttle tube and the throttle rod ( splined end type ). I've now come to the gearchange side. I've fitted the large plastic bush inside the housing, and slid the gearchange onto the handlebars with the thin shim that goes between the headset and the gearchange. There is another bush in the kit, similar to the one that goes into the end of the handlebars on the throttle side. Does this go on the gearchange side somewhere ? I thought it might go down inside the gearchange to support the rod, but it won't fit. Am I doing something wrong somewhere ?
JETEX
Re: Handlebar gearchange
Postby jonno » Sun Nov 02, 2014 12:57 pm
Have a look at Scooterrestorations site, they have exploded drawings which are helpful.
jonno
Postby landybretta » Sun Nov 02, 2014 8:56 pm
Scooterhelp.com have the original parts manuals available online foe all models.
http://www.scooterhelp.com/serial/lam.i ... books.html
landybretta
Postby JETEX » Mon Nov 03, 2014 1:57 am
Thanks guys, got it sorted now with the help of the exploded diagrams.
JETEX
Users browsing this forum: Google [Bot] and 54 guests
