Scootopia fuel tap
Scootopia fuel tap
Postby Charliescooter » Sat Sep 05, 2026 3:55 pm
Hi all just got a new scootopia fuel tap and in the kit is a rubber grommet and a washer so excuse my ignorance when I ask where do these go ? It seems they fit perfectly over the filter pipe so to sit in the 19mm top nut that attaches the tank?
Any help on the matter would be welcome?
Charliescooter
Re: Scootopia fuel tap
Postby Warkton Tornado No.1 » Sun Sep 06, 2026 4:13 pm
It’s been a while since I bought a Scootopia fuel tap but I can remember that the fuel filter is the usual - nowadays - ‘top hat’ design that incorporates the sealing washer into the filter. If your’s is the same, that is the method of sealing sorted. I come from the Lambretta generation where taps had to be took apart & ‘ported’ to realise good flow so the Scootopia tap was a revelation IMO being a neat, compact product that flowed well.
Perhaps the grommet - presumably ‘open’ - is intended for the frame where the control rod fits.
As with a tap of any manufacture, I advocate full dismantling prior to fit. Reason being that so often, burrs from the manufacturing process or debris can often be found & removed, Fuel flow rate should also be checked once fitted just for peace of mind.
Users browsing this forum: No registered users and 85 guests
