Exhaust rubbing against head cowl
Postby Peterp » Wed Jul 29, 2026 7:23 pm
Evening all.
This is an odd one. Fired up my 175 today after refurb bits etc, sounded bloody awful, I’m gutted.
It sounds as if something is loose but nothing is loose. Seems like a lot of vibration, new Cambridge Lambretta mounts fitted, new cones and bolt.
I had it rebored and new piston, but nothing else engine wise.
The only things I discovered was that the head cowl was tight against the downpipe and the exhaust box just behind the inlet was tight against the head cowl. Removed head cowl etc and ground away some clearance, as to exhaust box, the only fix for this was to pack out the bracket with washers.
I never remember having this sort of problem in my youth, or did I not care.
The other funny thing was when I fired it up without the box on, it seemed smoother,
I haven’t ran it since the above alterations, tomorrow for that.
The TV175 engine is suppose to be smooth, mine isn’t,
If anyone has a magic wand, can I borrow it please.
Peterp
Re: Exhaust rubbing against head cowl
Postby Storkfoot » Thu Jul 30, 2026 8:03 am
Hopefully, when you get back to looking at it today, it’ll become easily apparent where the issue is :D
If you have reused the body parts from an original scooter, parts that touch each other when they shouldn’t is quite unusual. In my case, it’s often down to user error :P
What exhaust have you fitted?
Postby Peterp » Thu Jul 30, 2026 9:53 am
Paul,
I’m more than happy to hold my hands up to “cocking” up. You’re probably right my friend, my failure is being ignorant to the anomalies of Lambrettas, I’m reliant on my experience when I was in my teens, memory fades.
I’m also wondering if it’s a memory issue, because I cannot remember how it did sound, I know it was a pleasure to ride,
And, I think I’m worrying, after rebore and new piston, I read loads about mixture, overheat, don’t overev’ don’t labour, I’m almost nervous about taking it out.
Daft eh’
I’m probably now known as that pain in the arse, but, if I’m unsure I’ll ask, especially if it’s not obvious to my mechanical eye/ear.
Peterp
Postby Peterp » Thu Jul 30, 2026 9:54 am
I meant to add that I’ve also been riding a Suzuki 800s, which is quite smooth
Peterp
Postby hullygully » Thu Jul 30, 2026 10:37 am
as long as your vibe noises arent coming from the inside of the barrel, inside the mag flange area, the crankcase side internals,
then it probs its just the frame / bodywork.
dont be afraid to rev her, as long as you've got 2T in the fuel, just dont labour the engine early doors in your first rides.
Postby Storkfoot » Thu Jul 30, 2026 12:28 pm
Assuming that it holds a tick over without having to blip the throttle, feel free to send me a video from either side of the engine. I’ll message you my email and phone number in case you want to do that.
Postby Peterp » Thu Jul 30, 2026 1:37 pm
Hello Paul,
Thank you, I will do that.
At least I’ll get expert advice/view
Peterp
Postby Storkfoot » Thu Jul 30, 2026 1:44 pm
No problem but I am no expert, believe me.
My last post should have said “both” sides not “either”.
Postby Warkton Tornado No.1 » Thu Jul 30, 2026 4:29 pm
It’s not all that easy to make any clinical diagnosis of precisely where a particular noise is coming from when - inherently - the thin, sheet steel of which Lambrettas are constructed act as a drum.
I can only suggest that with panels off, any rattling items - including toolbox lids, contents & panel clips secured or bungees attached, then the engine be fired up & the tickover adjusted to fast. The most likely unsafe sounds will be knocking or ‘pinking’ but there are likely to be sounds that you can identify to eliminate from your list of major concerns. Unfortunately, the OEM exhaust mounting is rigid, which method in itself contributes to noise. It can be improved & virtually eliminated via mounting modifications, but that may be for another day. The air filter box is also a source for noise. Even the rear shock absorber - unloaded as when the bike is on it’s stand - will often contribute. The stand & splash plate, tight chain, crankcase cover/kickstart lever catching the clutch, etc etc. A tool rarely mentioned these days is the ‘one eared stethoscope’ which is simply a long piece of fuel pipe tubing by which to listen in by holding to various parts of the engine.
I will venture to say that it is often the case that a replacement product from a trusted specialist supplier will not be on the same page as the OEM item. Replacement part quality not only affects us, but there are a lot of companies producing identical looking components in the car industry which will fail, as I can attest, having fitted a pair of rear upper shock absorber mounts to my car in January that made it as far as June. Having worked for some periods in the industry in which engineered, ‘rubber’ based automotive components are produced, I have some knowledge of the processes involved. Besides the ‘rubber’ being of a base consistency to endow desired properties to the finished component, the bonding of the materials involved will be so good that the component will likely fail for another reason prior to the integrity of the bond. In ‘proper’ anti-vibration components, such as a Lambretta engine mount, there will be additional processes after moulding to deliberately add desired properties to the ‘rubber’ by stressing it. In the case of the OEM engine mounts, that will have almost certainly have been to ‘swage’ the steel tube bore by pressing a tool through to give it the ‘finished’ size. Likewise, the spigot - in the case of the larger engine mounts - will be reduced from ‘moulded’ size to it’s finished size.
As far as I am aware, when Innocenti & it’s trusted suppliers ceased producing OEM components, probably the licensed Spanish suppliers & certain of the SIL parts manufacturers continued with the same methods of producing engine mounts. I think it would be naive to believe that without some kind of proof, or basis for trust, that reproduced engine mounts are going to be of the same quality. Imagine the costs involved in just the tooling for hydraulically reduced the spigot size :!: Unless things have changed, the last of the ‘two hole, no void’ engine mounts - despite being ‘solid’ rubber - are highly prized by racers & - probably! - more ex-racers, but that will be for reasons of handling improvements.
Sorry to have waffled on, but I’m attempting to paint a fuller picture as to the scenario as I see it. Don’t lose heart about this ‘teething’ problem. It’s far too easy to blame the scooter itself, but, of course, the real culprits inevitably will be those that set up in business selling us stuff that we trust in. That’s not to say that they are all alike, but they all exist to put groceries on their table…. ;)
Postby Storkfoot » Tue Aug 04, 2026 6:33 am
Peter, if it is you who have sent me those txts, no I have not received any video from you.
Postby Peterp » Tue Aug 04, 2026 9:19 am
Morning Paul, I’ll try again
Peterp
Postby Jeff t » Sat Aug 08, 2026 7:25 am
I had an issue for years with a noise not there all the time and i had tried everything to workout what it was but couldn't fix it. Anyway it was on my gp which has a long range fuel tank with the small cutout for a tool box where you can just about get a measuring jug in.
One day we are on the way to Ambleside we met some lads on the way and for some reason i looked for something in the tool box which i hardly ever use and found a spare cdi which was the culprit . To add to the irony setting off for home i couldn’t start the GP and guess what the cdi had gone and the only spare i had was the one i found on the way I know it doesn’t help you but shows sometimes its the bloody simple things.
Jeff t
Postby Peterp » Tue Aug 11, 2026 8:43 pm
Thank Jeff
Peterp
Users browsing this forum: Google [Bot] and 77 guests
