Gp racing
Gp racing
Postby L111amo » Mon Jun 15, 2026 4:42 pm
Hi all, my gp( casa185) kit been on about 15 years has started to hold revs up a bit when hot, changed ex gasket, inlet gasket & rubber, no difference, any ideas, thanks in advance
L111amo
Re: Gp racing
Postby Toddy » Mon Jun 15, 2026 4:50 pm
Do an air test
Re: Gp racing
Postby hullygully » Tue Jun 16, 2026 10:10 am
check your ring gap?
Re: Gp racing
Postby Warkton Tornado No.1 » Wed Jun 17, 2026 12:12 am
If the leak test includes inlet & exhaust manifolds & proves the engine to be air-tight, the ignition strobes up to be as desired setting, then there could be a carbon build-up causing pre-ignition. Spark plugs also can have a whisker or build-up to cause that. Fuel flow issues can also cause the problem so that includes tank, tap/filter, fuel pipes & carburettor.
Re: Gp racing
Postby L111amo » Wed Jun 17, 2026 3:18 pm
Gonna get a leak test done on it first, it holds up for 30 seconds or so then drops to normal, been to jersey & back( from Brum) in april with no issues apart from the high idle
L111amo
Re: Gp racing
Postby Warkton Tornado No.1 » Thu Jun 18, 2026 9:20 am
On the additional information: after the leak test - I often just use a cycle inner tube cut opposite the valve with one end stretched over inlet manifold, t’other over exhaust manifold/‘U’ pipe. You don’t need a gauge or even soapy water spray as deflation is obvious - I’d suspect carburation. Very likely a sticky float bowl/needle which may vibrate into working properly as soon as the engine is running.
Re: Gp racing
Postby L111amo » Thu Jun 18, 2026 7:32 pm
Hi, when you say once it’s running? It alwayscstarts first kick & runs fine then after a couple of miles hangs up, then drops down, samecevery journey etc, ??
L111amo
Re: Gp racing
Postby Warkton Tornado No.1 » Thu Jun 18, 2026 11:30 pm
L111amo wrote:Hi, when you say once it’s running? It alwayscstarts first kick & runs fine then after a couple of miles hangs up, then drops down, samecevery journey etc, ??
Yes, you are quite correct to be confused :oops: I lost the plot there!
Now that I’ve re-read the symptoms, although I still think it’s fuel delivery - if the leak test proves there is none - I suggest you check fuel flow throughout, from tank to fuel bowl.
