SIP wheel stud length?
Postby ianjc » Thu Jun 11, 2026 8:49 am
What length of bolt are we using?.
I have a set of SIP alloy wheels which were supplied with stud's, nuts, and Nord washers.
So measuring up I have a hub at 12mm the rim at 16mm, and a Nord washer at 2mm, giving me a total of 30mm. The bolts supplied are 40mm overall so deducting another 2mm for the bolt head this is only leaving me 8mm for the nut.
Is this correct, looking at other bolts they all appear to be 40mm overall and bolts advertised as actual SIP bolts I have seen are saying 39mm overall
ianjc
Re: SIP wheel stud length?
Postby hullygully » Thu Jun 11, 2026 11:13 am
in engineering we work on m5 as 5mm min length, m6 as 6mm min, m7 as 7mm min, m8 as 8mm min etc.............
Postby ianjc » Thu Jun 11, 2026 12:41 pm
hullygully wrote:in engineering we work on m5 as 5mm min length, m6 as 6mm min, m7 as 7mm min, m8 as 8mm min etc.............
Thanks, so looking like I have the minimum
ianjc
Postby gizmo » Fri Jun 12, 2026 1:01 pm
I'm not certain but I think the ones MB do are a tadge longer
gizmo
Postby ianjc » Sat Jun 13, 2026 2:20 pm
gizmo wrote:I'm not certain but I think the ones MB do are a tadge longer
I'm waiting for a reply from MB, rang a couple of times now they said they would get back to me, probably busy,there add says 41mm from underside of the bolt head Which I think would be perfect but there Questions & answers says 38mm. Anyone had any from them?.
ianjc
Postby nastro azzurro » Sat Jun 13, 2026 11:39 pm
I’ve got some mb ones. I’ll take a measurement tomorrow and let you know.
nastro azzurro
Postby ianjc » Sun Jun 14, 2026 12:16 pm
nastro azzurro wrote:I’ve got some mb ones. I’ll take a measurement tomorrow and let you know.
Great thanks
ianjc
Users browsing this forum: No registered users and 86 guests
