Ideas for Frame Tube Treatments?
Postby Adam_Winstone » Fri Mar 20, 2026 4:38 pm
Right, a question for the masses...
I note in various respected texts that it mentions, when looking to restore or rebuild a S3, temporarily filling the main frame tube with a rust inhibitor to treat any existing rust and avoid further corrosion. However, it makes no mention of what may be appropriate to use. All well and good, but considering the volume of the frame tube, that's a heck of a lot of something to pour in!
Anyone got any ideas of what can be bought in suitable volume that doesn't cost the earth? I was about to add for a 'one off use', however, I guess that it can then be drained and stored to reuse in the future.
Perhaps a diesel and heavier oil combo could be used.
Any thoughts?
Re: Ideas for Frame Tube Treatments?
Postby nsaints » Fri Mar 20, 2026 7:26 pm
Not attempted this before, however id use a two step process
Step 1 remove any corrosion using this. This stuff doesn't convert rust, but dissolves it to just clean bare metal
https://www.frost.co.uk/frost-safe-rust ... xic-acids/
Step 2 to prevent any future corrosion use ankor wax to coat the inside
Ive a gallon can of the stuff around here you can use.
nsaints
Postby Covboy » Fri Mar 20, 2026 9:41 pm
Any good for inside of petrol tanks Andy?
Postby nsaints » Fri Mar 20, 2026 10:30 pm
Ive used this last time i did a petrol tank went well
Wow everything seems much more expensive since last time i looked
https://www.frost.co.uk/fuel-tank-repair/
nsaints
Postby martyn dwane » Sat Mar 21, 2026 12:39 pm
ive used Oxalic acid to clean the rust out of tanks before.
https://trade-chem.co.uk/product/oxalic ... antity=1kg
martyn dwane
Postby tim_mason » Mon Mar 23, 2026 7:41 pm
[quote="Adam_Winstone"]Right, a question for the masses...
Sorry to jump on your query.
Any thoughts?[/quot out of interest what is the volume of a frame Tube , in litres Thanks in advance
tim_mason
