Class push down tensioner
PostPosted: Thu Oct 09, 2025 8:46 pm
by eadmr04
What’s the best way of checking the chain tension when fitting these as a pull down. Just trying to set one up and not sure what’s the best tension and where to measure it from?
Re: Class push down tensioner
PostPosted: Fri Oct 10, 2025 10:05 am
by hullygully
the same as a push up bud
PostPosted: Fri Oct 10, 2025 11:49 am
by Storkfoot
If I can get my index finger between the chain and the tensioner, at the ends of the tensioner, I’m happy. Don’t think of them as a tensioner though. They are more a means of keeping the chain from flapping around after the front sprocket has pulled the chain through from the bottom.
PostPosted: Fri Oct 17, 2025 6:45 pm
by Martin s
Steelweasel does a vid on u tube for the chain on a pull down.
