Casatronic 4 pole
Casatronic 4 pole
Postby jonoy » Tue Aug 05, 2025 9:21 pm
I have an older casatronic 4 pole electronic ignition.
I had to replace the 3 way earth strap.
One end goes to flywheel cowling one went behind the regulator box where it attaches
to the frame.
One end I found was wrapped around the black wire and pushed into the same receptacle via bullet connector
in the regulator.
Is that correct routing ?
jonoy
